Hi David,
Unfortunately I
don't think that is possible with a Stepper Motor.
Servo motors generate torque that is basically
proportional to current. But Stepper motors basically
apply constant current and the torque is more a
function of motor shaft angle. For example if you put
a large current into a stepper coil it will hold
position and generate no torque. You can tell it is
generating no torque because it is sitting still and
not accelerating like a DC motor would. But then as
you displace the motor shaft slightly from the holding
position torque will be generated while the motor
current remains unchanged.
Do you have
encoder feedback? If so there might be a way to
basically use following error to determine torque.
Actually
SnapAmp is capable of driving a Stepper Motor as a
4-phase Brushless servo motor but it is quite
complicated to setup and tune.
Message: 10854 |
Date: 1/17/2015 |
Subject: Re: Measuring Current in Stepper Motors with SnapAmp |
Hi David,
Driving Steppers as brushless motors isn't that difficult. It is similar to 3-phase brushless where commutation and tuning is involved except the commutation is more critical and there is more cogging and torque ripple to deal with.
But encoders are required so that isn't an option for you anyway.
Message: 10856 |
Date: 1/17/2015 |
Fair enough. I guess I need to figure out a plan B.
Thanks for your help,
David.
On 1/17/2015 3:35 PM, Tom Kerekes
tk@... [DynoMotion] wrote:
Hi David,
Driving
to deal with.
But encoders
